Bruder Cat 320 conversion |
ari
Erfahrungspunkte: 286.593
13.09.2011 21:07 |
| RE: Bruder Cat 320 conversion |
Erfahrungspunkte: 31.546.629
What type of conversion is this going to be?
If you use the original plastic for structural components (arm, knuckle, A-block), you probably can save some money and use the standard plastic tracks.
13.09.2011 21:37 |
In that case, the Veroma track is a good option.
They have one ugly cheap track and one good-looking more expensive track. Both would be suitable in strength for an excavator the size of the Bruder.
You can see the Veroma parts used in a build here:
http://rc-baustelle.de/thread.php?threadid=3573
13.09.2011 21:52 |
Erfahrungspunkte: 12.842.862
The Veroma tracks are great, but you need smaler sprocket wheels. The wheels from Veroma are much to huge (diameter).
13.09.2011 21:57 |
ari
Can someone who have Bruder Cat tell me what is distance between red lines in picture
20.09.2011 16:25 |
Erfahrungspunkte: 2.490.203
Including the tracks the distance amounts about 6cm.
20.09.2011 19:18 |
Hi Ari,
it`s easier to design your conversion when you have the Bruder excavator in front of you! My advice to you is get one
Concerning the sprocket wheels, you can use other tracks from Ingo.P. He uses sprocktes from Maedler if I`m not totally wrong. Ask him or Marcel, he uses the same tracks. That`s much easier than drawing new ones.
20.09.2011 19:36 |
I had the same problem with the size of the sprockets, that`s why I now build a bigger one
20.09.2011 20:57 |
ari
Original von Kawoom
I like to keep 1:16 scale because other models I have. If I don't find tracks and sprocets I have to do same but in 1:16 scale eg Cat 345D
20.09.2011 21:21 |
ari
20.09.2011 22:13 |
ari
Original von Marcel2612
Including the tracks the distance amounts about 6cm. |
Thanks!!
20.09.2011 22:13 |
They should be right, but you need to get other guide wheels, track roller and top roller. Do you have a turning center?
21.09.2011 09:32 |
ari
Original von Kawoom
They should be right, but you need to get other guide wheels, track roller and top roller. Do you have a turning center? |
I have a mill and my brother-in-law owns lathe so that is not a problem.
Cheers,
Ari
21.09.2011 11:50 |
Perfect conditions
21.09.2011 17:01 |
ari
What kind of remote controller could be suitable for excavator. I am not able buy expensive one, I am using cheap 2,4 GHz units in my other models but in this case I don't have any idea how to solve controlling of the tracks.
Any help?
Br,
Ari
17.10.2011 21:20 |
The cheapest radio with two sliders I know of is the FC-16 Boat&Truck, which is not exactly cheap and not natively 2.4GHz.
I would get a Turnigy 9x v2 and modify the replace the rotational potentiometers with sliders or a PlayStation Thumbstick, if you can't live with the rotational pots.
17.10.2011 21:35 |
ari
Thanks for the answer. This might be stupid question but can I replace rotational potentiometers with any sliding potentiometer (eg Futaba sliders)?
17.10.2011 21:51 |
Views heute: 712.362 | Views gestern: 775.766 | Views gesamt: 407.667.584
