RC-Baustelle.de » Modelle » Bagger » [1:14,5] CAT330D-L Full Hydraulic » Hallo Gast [Anmelden|Registrieren]
Zum Ende der Seite springen CAT330D-L Full Hydraulic
iaindunn
Level: 15 [?]
Erfahrungspunkte: 6.298
Nächster Level: 7.465
1.167 Erfahrungspunkt(e) für den nächsten Levelanstieg
Great work on the motors Erik and glad they got the cnc machining right. Are they producing enough torque or do you have to test further?
10.11.2014 08:57 iaindunn ist offline E-Mail an iaindunn senden Beiträge von iaindunn suchen Nehmen Sie iaindunn in Ihre Freundesliste auf
smile
Erik79
Level: 24 [?]
Erfahrungspunkte: 62.730
Nächster Level: 79.247
16.517 Erfahrungspunkt(e) für den nächsten Levelanstieg
Themenstarter Thema begonnen von Erik79
Hi Iain, fröhlich
in effect the motor has not got a well done cnc machining like you guess.
I have only done some micro adjustment to some components and the torque is raised slightly but is still not enough.
I have to improve it further!
I never give up! böse
Freude Freude Freude
10.11.2014 23:17 Erik79 ist offline E-Mail an Erik79 senden Beiträge von Erik79 suchen Nehmen Sie Erik79 in Ihre Freundesliste auf
smile
Erik79
Level: 24 [?]
Hello, fröhlich
After a long long time i'm here again with news.
Here is my new open center hydraulic valve, built to search the best in terms of smoothness, low actuation force, compactness and durability.
This time, for a longer lifespan, i built it with alloy steel hardened, a small production series for my and some friends.
The system is modular hence i can put together from 1 to 10 or more valves in an in-line assembly.
The video below shows three of them and only one with servo Hitec Hs82 installed.
This valves are already at work on a Cat 365 of a friend. The model weights 40 Kg and work at 45 BAR of pressure without any problem, so i'm quite happy. fröhlich
These valves will bring life even to my Cat 330.
https://youtu.be/OVUPcK1UuFo
04.05.2017 18:16 Erik79 ist offline E-Mail an Erik79 senden Beiträge von Erik79 suchen Nehmen Sie Erik79 in Ihre Freundesliste auf
Views heute: 64.430 | Views gestern: 135.904 | Views gesamt: 255.859.245
